SethOx
Dec 18, 2020Guide
LG TV keeps dropping connection to Orbi Satellite (RBK12)
Hi, I have an Orbi RBK12 and an LG smart TV. The Orbi router is upstairs at the front of the house, and the Orbi satellite is downstairs, one room closer to the back of the house. The TV is in the bac...
CrimpOn
Dec 18, 2020Guru - Experienced User
SethOx wrote:
As I say, this is only a problem with the TV our phones etc are fine. Is this a known problem that you can help with, or do I need to try to get help from the TV manufacturer?
There have been a few posts about LG TV's. I do not recall a post describing this particular issue.
My guess is the search most likely to succeed is (a) get a copy of the TV user manual and find the section about WiFi. Maybe there is something that has to be done to "lock in" the WiFi connection, (b) look for an LG FAQ about WiFi, (c) post a question in an LG user forum. (do they have one?)
Maybe if you list the exact LG model number, someone who watches this forum will have one. (slim, but possible)
- SethOxDec 19, 2020GuideThanks a lot, I’ll try all that.
The model number is LG - 50UK6470PLC, just in case someone can help
