SethOx
Dec 18, 2020Guide
LG TV keeps dropping connection to Orbi Satellite (RBK12)
Hi, I have an Orbi RBK12 and an LG smart TV. The Orbi router is upstairs at the front of the house, and the Orbi satellite is downstairs, one room closer to the back of the house. The TV is in the bac...
SethOx
Feb 05, 2021Guide
That's interesting to hear that you're having the same problem. It's actually improved since I did this post - for a month or two it worked with no problems at all, and then in the last few weeks it's started doing it again, but less often, typically only when we turn the TV off, rather than every time we switch from 'internet TV' to normal TV (and sometimes while we were watching). As far as I know, nothing changed that would explain the improvement, so I don't know how to explain it.
Chris1893
Mar 11, 2021Initiate
I have the exact same issue. I have 3 LG TVs, 2 are wired, 1 wireless and the wireless has to be manually connected to the wifi almost every time. Every once in a while it will auto connect. Having said that I have probably 25 devices in my home connected and everything worked great until I swapped over to Orbi - and that 1 TV is the only issue, everything else worked flawlessly.
- SethOxMar 19, 2021Guide
Sorry to hear you have the same problem. I guess it sounds like it might be an issue with LG TVs interacting with the Orbi? As I said in a previous post, the problem seems to have solved itself for us somehow (touch wood it's not temporary). I did a complete re-set up of the Orbi using the setup wizard a couple of times, and although the problem didn't stop immediately after I did that, I wonder if that had anything to do with it? I'd be interested to hear if you do manage to solve the problem yourself.
- Chris1893May 11, 2021Initiate
I resolved my issue although it shouldn't have been a fix. We had a thunderstorm and we had an outage on our ISP and wanting to stream TV I hooked up my Verizon Mifi, threw in the credentials and it connected right up. I forgot it the mifi was still on the next day, turned the TV on, went to re-enter the credentials (habit) and found it was connected. I left it like that for a couple of days and every time we turned on the TV it was quickly connected.
I've been through setting after setting on Orbi and had to re-enter the wifi credentials, often several times, to get it to connect, every time we turned the TV on.
One thing I noticed was my wifi credentials were 17 characters - my Verizon mifi length was 9. I changed my wifi password to something shorter and have not had an issue since then. It could purely be coincidence but I have not had to re-enter my credentials on that TV since that point and it's been great.
I also live 1/4 of a mile from anyone so if someone tries stealing wifi I'll see the van in the driveway lol :)
