Lauberge49's avatar
Lauberge49
LG TV Refreshing
I have the RBR20 and one satellite, and I have had the satellite connected directly to my LG Smart TV in the den, not more than 50-60’ from the base station. Over the past few weeks this particular gets into a refreshing mode, which is annoying. I have Spectrum Cable and download speed is 110-112, while upload is around 11-12.
We stream everything via YouTube TV
I moved the satellite away, and reset the TV Network connection, and it seems to be better.
Why would the direct connection not be consistent and faster?
Seems weird and my other TVs seem to work fine.
This was happening with just me in the house and just the TV and my IPAD online at the time.
  • CrimpOn's avatar
    CrimpOn
    A distance of 50-60 feet between the router and satellite may be too far to maintain a good backhaul signal.  The general recommendation is to start at about 30 ft. between them and see how that works.  What does the Orbi web interface show about the satellite connection?
    (On the Basic Tab, "Attached Devices")  Does it show the backhaul status as "Good"?
    • michaelkenward's avatar
      michaelkenward
      My thought exactly. That's a stretch for a lot of wifi stuff, especially of there is local interference, from the neighbours for example.
      My strategy for connecting fixed stuff that I do not move around, TVs for example, is to use Powerline Ethernet. It is more reliable, and usually faster, than wifi.
      • Lauberge49's avatar
        Lauberge49
        Date: Mon, 9 Sep 2019 06:49:22 -0700
        Subject: Re: LG TV Refreshing (NETGEAR Communities Subscription Update)
        So I thought the satellites were for extending the signal to the far reaches of your home. That always involves a distance of more than 30’. I am confused.
        I am watching the tv this morning and no lag without the satellite.
        I am confused.......
