Ckj4
Dec 18, 2017Aspirant
LG TV will not connect to Orbi RBK50
Installed Orbi router and two Sats, and LG TV will not find/search the wifi network. LG TV worked fine with prior Dlink wifi router. All other devices work on Wifi. LG TV will connect to cable modem wifi (when enabled), but not the Orbi wifi. Any help on what the issue is? I think the LG TV is working fine, but will not connect/see the wifi network. Enabled a guest network and still nothing.
1 Reply
- DarrenMSr. NETGEAR Moderator
I am guessing the Tv is not liking the mesh network and wants to connect to a single band network. I would check and see if the tv has any firmware updates.
DarrenM
