T-E-R
May 02, 2020Tutor
Light stays on.
When the main unit is connected directly to hot CAT6 cable, the light on the top of the unit stays on. Function and connection to satellites appears uninterrupted. Good to goORBI!! SOlved wireless...
May 02, 2020Guru - Experienced User
https://kb.netgear.com/31030/What-do-the-LEDs-on-my-Orbi-mean
