T-E-R
May 02, 2020Tutor
Light stays on.
When the main unit is connected directly to hot CAT6 cable, the light on the top of the unit stays on. Function and connection to satellites appears uninterrupted. Good to goORBI!! SOlved wireless...
CrimpOn
May 02, 2020Guru - Experienced User
T-E-R wrote:When the main unit is connected directly to hot CAT6 cable, the light on the top of the unit stays on. Function and connection to satellites appears uninterrupted.
This does not match how Netgear says the "Ring Light" should behave. It is supposed to disappear once the Orbi is in normal operation.
https://kb.netgear.com/31030/What-do-the-LEDs-on-my-Orbi-mean
Interesting that "everything works".
