MarkGould13
Jul 12, 2021Aspirant
Limit device to LAN using RBR50v2
I am trying to do something with my Orbi system (RBR 50) that may not be possible. (Certainly, I have yet to find a way to achieve it.) I have a device on my network that does not need to connect...
- Jul 12, 2021
MarkGould13 wrote:I have a device on my network that does not need to connect to the wider internet. I can see that it is possible to control the device's access to the network, but I think that will shut it off from the LAN as well as the WAN. Is there a way of allowing LAN access but not WAN access?
Have you tried the Orbi web interface, Advanced Tab, Security Menu "Block Services"?
Set up one block for "Any" services, ports 1-65535 on the IP address of that device. and make the Schedule "Always".
CrimpOn
Jul 12, 2021Guru - Experienced User
MarkGould13
Jul 14, 2021Aspirant
Thank you CrimpOn -- that seems to have done the trick. (I had seen the function, but I thought it would block internal and external traffic alike.)
