nagendraprasath
Jun 09, 2020Aspirant
Limited Connectivity on 5GHZ
My townhome is about 1600 sq.ft and below is my setup. Please note, the same setup has been working for the past one year. Router in the living room One satellite in bedroom One satellite in the ...
nagendraprasath
Jun 10, 2020Aspirant
Thanks for the suggestion. Unfortunately it didnt help. I switched off all satellites except one, removed them from the router but still getting limited connection :(
I had to use atleast one satellite at my garage where the main router's signal is weak. Moreover router + 2 satellites have been working good. Not sure what went wrong recently.
Jun 11, 2020Guru - Experienced User
What modem are you using?
Does it work with just the router?
If not, have you tried factory resetting and reinstalling the system?
- nagendraprasathJun 11, 2020Aspirant
I use SB6183 (Motorola Arris) with this router since 2018 and satellites were added during feb 2019. Again, the setup has been working without any issues.
I've not tried reset yet. Just wanted to avoid the pain and not sure it'll fix. Anyways will try and update.
- FURRYe38Jun 11, 2020Guru - Experienced User
What happens if you turn OFF ALL RBS and just leave the RBR running alone?
nagendraprasath wrote:I use SB6183 (Motorola Arris) with this router since 2018 and satellites were added during feb 2019. Again, the setup has been working without any issues.
Good Question!
Yes, when all satellites are switched off, my phone connects to router with 2.4ghz from guest room and has internet connectivity.
I also tried with only RBS50 satellite, phone connects to 5GHz and has internet connection.
Problem seems to be with the Satellite RBW30
But given the fact that they were working earlier makes me think some recent firmware upgrade isnt compatible with router RBR50(V2.5.1.16) and satellite RBW30(V2.5.0.2). Looks like both firmware got upgraded during 04/20 and 04/22.Do you suggest i revert the firmware and try? not sure downgrade will lead to any instability.
