TyBreaker
Mar 11, 2025Aspirant
Limited download speed on Netgear Orbi AC3000 RBK50v2
Hi folks, I have a Netgear Orbi AC3000 RBK50v2 system with one router and one satellite which has been working fine with my TPG 100Mbps Internet plan. My wifi-connected PC routinely showed 100+Mbps ...
Mar 11, 2025Guru - Experienced User
Armor, IPv6, Smart Parental Controls or Circle, Traffic Meter.
Has a power off for 1 minute then back ON with the ISP modem and router and satellites been performed ?
Turn off and unplug modem.
Turn on computers and rest of network.
This happen on a 2nd computer to compare results?
- TyBreakerMar 11, 2025Aspirant
Hi FURRYe38, thanks for responding!
What Firmware version is currently loaded? I have the latest: 2.7.5.6
What is the Mfr and model# of the Internet Service Providers modem/ONT the NG router is connected too? I'm on the NBN with FTTP so it's whatever they installed. It appears to allow 640Mbps through to the router so I'm confident it's working OK.Try disabling the following and see:
Armor: already not activatedIPv6: already disabled
Smart Parental Controls or Circle: already disabled
Traffic Meter.: already disabled
Has a power off for 1 minute then back ON with the ISP modem and router and satellites been performed ? Yes, I did this as part of activating the faster Internet plan.
Turn on computers and rest of network.This was done as part of activating the faster Internet plan.
This happen on a 2nd computer to compare results? My Google Pixel Pro mobile phone does better and gets between 300-400Mbps on wifi. Maybe this means my Windows PC needs tweaking in some way?
