TyBreaker
Mar 11, 2025Aspirant
Limited download speed on Netgear Orbi AC3000 RBK50v2
Hi folks, I have a Netgear Orbi AC3000 RBK50v2 system with one router and one satellite which has been working fine with my TPG 100Mbps Internet plan. My wifi-connected PC routinely showed 100+Mbps ...
TyBreaker
Hi CrimpOn, thanks for responding! I acknowledge the different wifi standards between my PC and my router, though the newer standard is backward compatible so should allow the older standard to achieve its maximum speed? Wifi5 still allows nearly 7Gbps apparently, though the Orbi doco seems to indicate 3000 max.
I may not be completely across the maximums but I was expecting to receive close to what the router can deliver and it's receiving approx 640Mbps.
CrimpOn
Mar 11, 2025Guru - Experienced User
Yes, the new PC WiFi adapter is "backward compatible". After detecting that the Orbi does not support the 6GHz frequency band (WiFi6E) and does not support WiFi6 (802.11ax), the adapter will connect to the Orbi 5GHz band using WiFi5 (802.11ac). It might be worth doing a bit of internet search with terms such as "realistic connection speed for WiFi5".
When companies market their WiFi systems, they seem to enjoy adding together all the theoretical WiFi link speeds to arrive at some "magic number". For the RBK50, the maximum theoretical Link Rate for 2.4G is 400Mbps, for user 5G is 833Mbps, and the backhaul 5G WiFi link is 1,733Mbps. (400+833+1,733 = 2.999Mbps) So, Netgear markets this system as AC3000. Wow! (Not just Netgear. Every vendor does similar arithmetic.) Never mind that the WiFi backhaul connects the router and satellites and is not available for user connections. Never mind that those theoretical maximums are conceptual calculations rather than "real world" observations.
