k3n85
Apr 09, 2020Tutor
Link rate incorrect when device connected to Orbi satellite
Hi everyeone - Recently while doing some WiFi troubleshooting with the Orbi system, I was noticing some inconsistencies with the Link Rates showing for my devices when connected to the RBW30 Orbi...
k3n85
Apr 09, 2020Tutor
Tech nerd here, so I check for firmware updates regulary on most of my electronics. Both Router and Satellite are both up to date with their firmware. I've done a reset on the Satellite, re-added it as well as relocated it just to see if there was any other type of glitch. I'm seeing this incorrect Link Rate for all 2.4 / 5 Ghz devices to the Satellite, but all to the Router seem correct.
I can't really see the "Link Rate" from the Orbi Web Interface, pretty lack luster, so can't really confirm if this is an app or Orbi device issue.
Apr 09, 2020Guru - Experienced User
I would make contact with NG support about this. Possible app and RBW issue in regards to link rates coming in from the RBW.
k3n85 wrote:Tech nerd here, so I check for firmware updates regulary on most of my electronics. Both Router and Satellite are both up to date with their firmware. I've done a reset on the Satellite, re-added it as well as relocated it just to see if there was any other type of glitch. I'm seeing this incorrect Link Rate for all 2.4 / 5 Ghz devices to the Satellite, but all to the Router seem correct.
