rp2955
Aug 13, 2019Aspirant
Link Rate issue after firmware update?
Hey all, just recently updated my RBR50 and 2 RBW 30s to the latest firmware. When I check them in the Orbi App, the link rates seem to be screwed up. For example, most of the link rates are showing n...
rp2955
Aug 26, 2019Aspirant
The satellites are on V2.3.5.6 and router is on V2.3.5.30.
Retired_Member
Aug 26, 2019
rp2955 wrote:The satellites are on V2.3.5.6 and router is on V2.3.5.30.
V2.3.5.30 for the router is known to have issues.
And how did the update come about? Did you do it?
- rp2955Aug 26, 2019Aspirant
Yes. I am not trying to overengineer this...I was just hoping someone who had the same satellites and downloaded the same firmware can confirm that they either see this same issue or not. If not, I likely need to factory reset my setup. Its more of an annoyance than anything else as my speeds are just fine.
- Retired_MemberAug 26, 2019
rp2955 wrote:Yes. I am not trying to overengineer this...I was just hoping someone who had the same satellites and downloaded the same firmware can confirm that they either see this same issue or not. If not, I likely need to factory reset my setup. Its more of an annoyance than anything else as my speeds are just fine.
Do a search for V2.3.5.30 topics in this forum.
