Antoine78
Jan 30, 2018Aspirant
List of connected devices doesn't appear anymore !!
Hi, i have installed my RBK50 (Base + Satellite) in AP mode (Access Point mode). The configuration went well and was pretty easy. I have also upgraded the firmware without any problem (curently v ...
DarrenM
Feb 01, 2018Sr. NETGEAR Moderator
You may want to factory reset the orbi unit after upgrading firmware it could of caused something strange to happen with your settings.
DarrenM
- Antoine78Feb 04, 2018Aspirant
DarrenMSo i f i hard reset my Orbi, and i already backuped my config (cfg file) can i restore it and retrieve my config as i configured it ???
Will i retrieve my connected devices list ?
P.S. : i already heard about hard resetting the config somewhere else, so i just need to understand if i have to reconfigure everything manually or if restoring my .cfg file is enough.
