Antoine78
Jan 30, 2018Aspirant
List of connected devices doesn't appear anymore !!
Hi, i have installed my RBK50 (Base + Satellite) in AP mode (Access Point mode). The configuration went well and was pretty easy. I have also upgraded the firmware without any problem (curently v ...
DarrenM
Feb 01, 2018Sr. NETGEAR Moderator
You may want to factory reset the orbi unit after upgrading firmware it could of caused something strange to happen with your settings.
DarrenM
Antoine78
Feb 04, 2018Aspirant
DarrenMSo i f i hard reset my Orbi, and i already backuped my config (cfg file) can i restore it and retrieve my config as i configured it ???
Will i retrieve my connected devices list ?
P.S. : i already heard about hard resetting the config somewhere else, so i just need to understand if i have to reconfigure everything manually or if restoring my .cfg file is enough.
