Antoine78
Jan 30, 2018Aspirant
List of connected devices doesn't appear anymore !!
Hi, i have installed my RBK50 (Base + Satellite) in AP mode (Access Point mode). The configuration went well and was pretty easy. I have also upgraded the firmware without any problem (curently v ...
Sevo123
Feb 02, 2018Apprentice
Getting a similar issue with my rbk53 system. Wont show me all my devices that are connected. On latest update! Netgear needs to get their act together fix this! Dropped connections, slow speeds, attached devices not showing
Antoine78
Feb 04, 2018Aspirant
Sevo123I agree, for that price, this should not suffer such malfunction / bug !
- budyFeb 04, 2018Luminary
You surely should backup your config, before performing a factory reset, but it could very well be - just as Darren noted, that the settings of your device(s) have been screwed up. In that case restoring your current config would surely re-introduce your issue.
However, it may be worth a try to factory reset and then restore your config… The question is, if your issue is actually caused by a config issue, or some other problem and if your issue is caused by a config issue, will the backup include this error. No other way to find out, then to try, I guess.
- Antoine78Feb 08, 2018Aspirant
Ok i'll try this week-end to not disrupt my familly with this during the week , as internet is our working tool and is allways in use ;-)
i'll keep you informed
- cotchonJun 25, 2018Aspirant
Same for me, firmware V2.1.4.16
French was selected, I switched back to English and it resolved the problem.
Thank you Netgear support ... Factory reset is not the solution to everything ...
