Antoine78
Jan 30, 2018Aspirant
List of connected devices doesn't appear anymore !!
Hi, i have installed my RBK50 (Base + Satellite) in AP mode (Access Point mode). The configuration went well and was pretty easy. I have also upgraded the firmware without any problem (curently v ...
Antoine78
Feb 04, 2018Aspirant
Sevo123I agree, for that price, this should not suffer such malfunction / bug !
budy
Feb 04, 2018Luminary
You surely should backup your config, before performing a factory reset, but it could very well be - just as Darren noted, that the settings of your device(s) have been screwed up. In that case restoring your current config would surely re-introduce your issue.
However, it may be worth a try to factory reset and then restore your config… The question is, if your issue is actually caused by a config issue, or some other problem and if your issue is caused by a config issue, will the backup include this error. No other way to find out, then to try, I guess.
- Antoine78Feb 08, 2018Aspirant
Ok i'll try this week-end to not disrupt my familly with this during the week , as internet is our working tool and is allways in use ;-)
i'll keep you informed
- cotchonJun 25, 2018Aspirant
Same for me, firmware V2.1.4.16
French was selected, I switched back to English and it resolved the problem.
Thank you Netgear support ... Factory reset is not the solution to everything ...
- BeejourcavaSep 11, 2018Aspirant
Hello
Thanks a lot for your help
i had the same problem on a brand new system rbk50 with last firmware . I tried everything since 2 days....then i found this post...
The app dont like French option !! Really a Big Big Bug !!
So French option should be deleted
