PeterEvansNG's avatar
PeterEvansNG
List the attached devices on Orbi Guest Wi-Fi network
Hello, is there any funtion/command to list the attached devices on Orbi Guest Wi-Fi network ? I could not find this function in web admin console. Is it available in CLI telnet console ? I'm fine if command can do the same.
The details of my Orbi :
Hardware Version RBR40
Firmware Version V2.2.1.210
Past discussion I found
Attached devices on guest network
https://community.netgear.com/t5/Orbi/Attached-devices-on-guest-network/td-p/1409281
Cheers,
Peter
  • In “Attached Devices” in the web GUI and in “Device List” in the Orbi app you can see all devices connected to your system.
    Devices connected to the guest wifi will be marked as 5GHz-Guest or 2.4GHz-Guest.
