jcartersd
Aug 27, 2018Follower
Loading firmware for RBK50 – Orbi AC3000 Tri-band WiFi System
I'm think I need to update my firmware and the only choice is RBR50. Is that the correct firmware for my RBK50?
Aug 27, 2018Guru - Experienced User
Did you type in RBK50 Should come up. However yes...same as RBR50.
