Testyblahblah
Apr 04, 2019Aspirant
Local IP connectivity to router apparently dead while WiFi still working
Hello, This morning our routing stopped working. WiFi still functions. I am not a networking amateur and have custom DHCP range and numerous fixed allocations set and so do not want to just reset the...
- Apr 05, 2019Good sanity testing fundamentals, thank you, although I have fixed this. I believe that I have revealed what can be used to diagnose the exact problem in this upgrade.
Repeated resets, repeated FW upgrades to the latest all achieved nothing. But, I immediately restored settings everytime, as per sensible guidance here. It should not have been a problem, but it was. This 'restored' the problem that the firmware introduced. This begins to make the problem isolatable by Netgear.
So, I manually created my complex DHCP fixed structure and my SSID details. And it works now. Between devices and Orbi units. I should not have to do this.
This means that something in the configuration structure does not port well between these firmware versions. I presume it has something to do with routing/iptables that this new App Armor thing has poorly implemented, regardless of whether it is enabled(!) (I do and did not have it enabled).
None of this is good news. I have two ruined days. And I would be irrational to trust my Netgear equipment. The scenario if I were travelling would be worse. If you have a NAS, an inward VPN, CCTV, alarms, Ring doorbells, Arlo or are just a modern user, you cannot trust a system or manufacturer that will destroy your network whenever it wants.
I am furious.
Apr 04, 2019Guru - Experienced User
Make contact with a forum moderator and see if they can help you on this.
I think there maybe something missing or the system is bad, I don't see how the system could be bad though if only 8 months old.
After doing the reset with a wired PC and just the RBR, do you get an IP address from the RBR? No even connected to the ISP router.
I would try this while you wait for help. If you can get an IP address and get online with the RBR, I would fresh re-load the v44 FW file to the RBR and then reset once more and setup from scratch. I would use IE11 or Firefox browser to do this.
Just seems like maybe the RBR is in a bad state. Might even try the 30-30-30 reset as well.
Testyblahblah
Thank you - appreciated.
Cable modem shouldn't matter as Netgear problem also applies when modem is off. Modem is a Virgin Media Superhub 3 (made Arris maybe). It is in modem mode when not off.
Blanca_O can you please review? I am extremely unhappy and have already investigated credit card reverse charging for these Orbi units.
Thank you
Thank you
- TestyblahblahApr 04, 2019AspirantI should have added that LAN DHCP has always been successfully working, IP addresses seen as allocated both on the router and on the devices themselves (including the problem devices receiving DHCP allocations, including any DHCP amendments). This is true before and after reset.
This means to.me that something further up the network stack has been ruined on the router - TestyblahblahApr 05, 2019AspirantFYI extra detail
I telneted into the router and was unable to ping one of the problem devices.
To summarise relevant points from above again:
The device receives an address via DHCP
It can ping the satellite, even when connected to the router wifi AP MAC
But it cannot ping the router and is unpingable from the router telnet terminal
Internet is obviously therefore inaccessible, as is router web interface
None of the above applies or applied to the laptop on 5ghz, which remains fine with no issues at all.
Two Huawei phones on 2.4ghz and one Samsung tablet on 5ghz have dead IP connectivity since your firmware update
