Testyblahblah
Apr 04, 2019Aspirant
Local IP connectivity to router apparently dead while WiFi still working
Hello, This morning our routing stopped working. WiFi still functions. I am not a networking amateur and have custom DHCP range and numerous fixed allocations set and so do not want to just reset the...
- Apr 05, 2019Good sanity testing fundamentals, thank you, although I have fixed this. I believe that I have revealed what can be used to diagnose the exact problem in this upgrade.
Repeated resets, repeated FW upgrades to the latest all achieved nothing. But, I immediately restored settings everytime, as per sensible guidance here. It should not have been a problem, but it was. This 'restored' the problem that the firmware introduced. This begins to make the problem isolatable by Netgear.
So, I manually created my complex DHCP fixed structure and my SSID details. And it works now. Between devices and Orbi units. I should not have to do this.
This means that something in the configuration structure does not port well between these firmware versions. I presume it has something to do with routing/iptables that this new App Armor thing has poorly implemented, regardless of whether it is enabled(!) (I do and did not have it enabled).
None of this is good news. I have two ruined days. And I would be irrational to trust my Netgear equipment. The scenario if I were travelling would be worse. If you have a NAS, an inward VPN, CCTV, alarms, Ring doorbells, Arlo or are just a modern user, you cannot trust a system or manufacturer that will destroy your network whenever it wants.
I am furious.
scofficial
Apr 06, 2019Aspirant
Thanks for the information. It really helped me!!
