Testyblahblah
Apr 04, 2019Aspirant
Local IP connectivity to router apparently dead while WiFi still working
Hello, This morning our routing stopped working. WiFi still functions. I am not a networking amateur and have custom DHCP range and numerous fixed allocations set and so do not want to just reset the...
- Apr 05, 2019Good sanity testing fundamentals, thank you, although I have fixed this. I believe that I have revealed what can be used to diagnose the exact problem in this upgrade.
Repeated resets, repeated FW upgrades to the latest all achieved nothing. But, I immediately restored settings everytime, as per sensible guidance here. It should not have been a problem, but it was. This 'restored' the problem that the firmware introduced. This begins to make the problem isolatable by Netgear.
So, I manually created my complex DHCP fixed structure and my SSID details. And it works now. Between devices and Orbi units. I should not have to do this.
This means that something in the configuration structure does not port well between these firmware versions. I presume it has something to do with routing/iptables that this new App Armor thing has poorly implemented, regardless of whether it is enabled(!) (I do and did not have it enabled).
None of this is good news. I have two ruined days. And I would be irrational to trust my Netgear equipment. The scenario if I were travelling would be worse. If you have a NAS, an inward VPN, CCTV, alarms, Ring doorbells, Arlo or are just a modern user, you cannot trust a system or manufacturer that will destroy your network whenever it wants.
I am furious.
scofficial
Apr 06, 2019Aspirant
Thanks for the information. It really saved me!!
Testyblahblah wrote:
Hello,
This morning our routing stopped working. WiFi still functions. I am not a networking amateur and have custom DHCP range and numerous fixed allocations set and so do not want to just reset the router... To emphasise what is below, WiFi is fine, would not need tweaking and I couldn't anyway (web interface down).
Scenario is this:
- Woke up to no external routing after 8 months of happy Orbis
- No other routers on network, cable modem only, also tested with modem off
- Router and Satellite WiFi APs are both connectable from WiFi devices - verified by AP MAC
- Router and Satellite do pair/connect to each other successfully and offer unified LAN as it should e.g. satellite IP pingable when connected to router AP or Satellite AP
- identical behaviour regardless of which WiFi AP/MAC I am connected to e.g. ping responses or lack of responses
- router web interface no response
- router ping no response
- router port scan shows only 20005 open
- tried Telnet on Port 23 just in case I'd left it open by accident... Nothing, as expected, as I was sure it was closed.
- router and satellite restarted several times
Does this make any sense? I had not even logged into the web interface to make any changes for many, many months. Something has seriously gone wrong. Auto updating firmware was on, I think, maybe. Or maybe it was auto version checking on the web panel - don't remember....
Any help very appreciated!
Apr 06, 2019Guru - Experienced User
Be sure to save off a new backup config to file after new FW has been loaded and your system is setup.
