Ppanfil's avatar
Ppanfil
Local IPv6 on RB750
I am trying to change my DNS servers on the Orbi RBK752 (AX4200) running V3.2.17.12 to my own, Pi-Hole DNS servers.
I've searched up some things, and apprarently NETGEAR does not allow for local DNS servers to be used, but wanted to check and see if anyone else found a way to set this!
  • CrimpOn's avatar
    CrimpOn
    Of course it does.  I set up my Pi-hole as an experiment. Worked fine. (I did not configure the IPv6 for that test).  Orbi handed out its own IP as part of the DHCP setup, but rather than use the ISP's DNS servers, CloudFlare, Google, etc. I just pointed to the Pi-hole.
    Devices ask Orbi, "where is abc.com?" Orbi asks Pi-hole "where is abc.com?" and Pi-hole asks where I pointed it "where is abc.com?" and then they all merrily cache the results (Pi-hole, Orbi, device)
  • FURRYe38's avatar
    Please visit and post about this over in the Orbi AX forum:
    https://community.netgear.com/t5/Orbi-AX/bd-p/en-home-orbi-ax
    Thank you.
