PlatinumGoat
Mar 26, 2018Apprentice
Location of satellite
Hi Everyone, I purchased the Orbi RBK50 set recently and would like to seek your advice regarding the placement of the satellite. I live in a small 1,200 square feet apartment. My source of inter...
Mar 26, 2018Guru - Experienced User
A more central location of the main router maybe more of a suggestion then place the satellite where needed. Usually placement of the router on the main floor and centrally in the home is best.
My 5000sq ft house has 40ft between the router and satellite for my configuration..
RocketSquirrel
Mar 26, 2018Luminary
The RBK50 is a pretty powerful system. Disconnects are likely to be a firmware problem. Update to the latest 2.1.3.4 firmware and see whether that helps.
