PlatinumGoat
Mar 26, 2018Apprentice
Location of satellite
Hi Everyone, I purchased the Orbi RBK50 set recently and would like to seek your advice regarding the placement of the satellite. I live in a small 1,200 square feet apartment. My source of inter...
Mar 27, 2018Guru - Experienced User
What is the distance between router and Satellite?
Mines about 40 feet and have great operation.
- PlatinumGoatMar 27, 2018Apprentice
Mine is about 30 feet away with walls in between. If you say yours is performing greatly, did you try to do speed tests while roaming between units? I just think that the "switching" mechanism isn't fast enough. If I managed to connect to the nearest unit, things are great too!
- FURRYe38Mar 27, 2018Guru - Experienced User
Yes, I had to do a before and after installation test with mine. Tested my prior router in place then tested with the Orbi router in place. Range, coverage, operation and Performance was way better then the NG XR500 single router I had in place. Which is no slouch.
