Wildfire13
Jul 30, 2018Aspirant
location of satellite
RBK50
Hi, I have a 20 wide by 66 long home on a 123 ft long lot in the city of Chicago. Electrical, phone, cable, etc. wiring runs in the ally along the entrance to my garage. My cable line com...
Jul 30, 2018Guru - Experienced User
How far away in the back hard and the garage is from the house? I get signal about 15 feet from my 1 satellite out side, however it's near a window on the main floor. My friends 50 series I set up for him, I had signal in my car at about 30 feet from his satellite up stairs in his living room. He's only using 1 satallite.
I presume you may need a outdoors Orbi...depending upon building materials.
Wildfire13
My house is Frame with Brick as is the garage. I have a garage rooftop deck and from where the house ends is about a 15 ft back yard to the garage and the garage is 20 wide x 23 long right to the ally. My main router satellite is about 40 ft from the back of the house below grade walk out basement. The main floor unit is about 55 ft from the back skewed towards the fron and the upper level unit is about 20 ft from the back. If I move the upper unit closer to the back wall it looses its connection to the main unit in the basement.
- FURRYe38Jul 30, 2018Guru - Experienced User
Ya you'll need an outdoors satellite to help with the back yards and garage areas.
