Ranboco
Apr 19, 2021Aspirant
Lock a product (via Mac Address) to a specific RBR50 satelite
Greetings, I have a Netgear Orbi RBR50 and for some reason even though I am only 15' away from the satelite (slave) on my 3rd floor, my work PC (running Win10) appears to always connect to the m...
Ranboco
Yes, you are correct, it works temporarily but whenever I sleep or restart the PC it locks back onto the weaker signal. Perhaps Microsoft can advise a method to fix this in their settings.
Apr 19, 2021Guru - Experienced User
Yes the signal will be reduced.
Ensure the wifi adapter drivers are up to date on the PC.
