dsachnoff
Aug 19, 2023Aspirant
Locked Out from accessing the Orbilogin.com
I was logged in to orbilogin and I went to Web Services Management and I selected "Always Use HTTPS to access Router" and found myself locked out of the login. I guess I am not sure how this function works and how to access Orbi management with this option enabled. I ended up using the ip address of the router and overrode some of the statements. In addition, how can I extend the time after login to the management system before being logged out. It appears to have a very short time period before you get logged out.
Don
- microchip8MasterUse https instead of http
- dsachnoffAspirant
I did but that did not work.
Don
Turn off "Always Use HTTPS to access Router".
For years people have complained that routerlogin uses http, usually because they don't understand what us going on. So Netgear may have added the https option for the terminally paranoid.
Unless you have discovered a need for this feature, join the rest of us and turn it off.
