dsachnoff
Aug 19, 2023Aspirant
Locked Out from accessing the Orbilogin.com
I was logged in to orbilogin and I went to Web Services Management and I selected "Always Use HTTPS to access Router" and found myself locked out of the login. I guess I am not sure how this functio...
KevinLiT
Aug 21, 2023NETGEAR Moderator
Hello dsachnoff ,
If you are unable to access your router since changing the HTTPS login settings then you will need to factory reset your router to regain access.
Please navigate to the link below for video instructions on how to successfully factory reset your Orbi Mesh System:
https://kb.netgear.com/31486/How-do-I-reset-my-Orbi-system-to-factory-default-settings
Best,
Kevin
Community Team
dsachnoff
Aug 22, 2023Aspirant
I was successful using the ip address to gain access to router and I proceeded to disable the use of https.
Don
Don
