DG1980
Nov 11, 2020Tutor
Login to Orbi router displays not secure, using HTTP instead of HTTPS
After I log in to my router, connection status on the browser shows "Not secure". I click the exclamation icon and see "Your connection to this site isn't secure". I'm using the latest firmware, V2.7...
Nov 11, 2020Guru - Experienced User
The browser is doing that.
What happens if you use HTTPS://192.168.1.1?
It's not a security issue if you use HTTP vs HTTPS on the LAN side for the mangement page.
Though NG has now fully supported HTTPS using this FW version:
- DG1980Nov 11, 2020Tutor
I get a security warning then choose to proceed anyway. It lets me in but the https is crossed out (see screenshot). Also, the firmware version is 2.7.1.60, which is newer than the one you suggested and "Always Use HTTPS to Access Router" is enabled (see screenshot).
- FURRYe38Nov 11, 2020Guru - Experienced User
Actually v2.7 is a different fork from v2.6 and v2.7 has different features from V2.6. v2.7 is meant for USA region users only.
Always Use HTTPS to Access Router is used for remote access from remote locations from the WAN side. This doesn't enable HTTPS on the LAN side of the router on it's web page.
You're wrong about "This doesn't enable HTTPS on the LAN side". The option "Always use HTTPS" is intended specifically for Local Management (i.e. LAN). Remote management already includes the https prefix. Refer to screenshot again and you'll see it.
Btw, I live in the USA so the firmware applies to me.
