DG1980
Nov 11, 2020Tutor
Login to Orbi router displays not secure, using HTTP instead of HTTPS
After I log in to my router, connection status on the browser shows "Not secure". I click the exclamation icon and see "Your connection to this site isn't secure". I'm using the latest firmware, V2.7...
Nov 11, 2020Guru - Experienced User
I would contact NG support about the local management to see if this is the case with v2.7.
The remote mangement option is for the WAN side only though when Turn Remote Managment ON is enabled:
schumaku
DG1980 Even if there is https support for the LAN - there is no f***n way that https://[LAN-IP] (or even a hostname put in by some tricks) will show anything different but a security warning, and on continuing a red "Not secure" on top in the current modern web browsers. nothing groundbreakingly wrong with it...
