Gellie
Jan 25, 2020Aspirant
Logitech Squeezebox continues to lose connectivity
Just started. Not sure if there was some software update? It stays connected to the 2.4ghz satellite (25 feet away) for several hours, perhaps days. Then disconnects and I need to reboot the Touch. A...
Jan 25, 2020Guru - Experienced User
Has a full power OFF of the Orbi system and ISP modem for 1 minute then back on with the modem to let it sync then ON with the Orbi system been performed yet?
Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
- GellieJan 25, 2020Aspirant
Running 2.5.1.8. Tried all channels you mentioned. I have unplugged Fios router, main Orbi and the 3 satellites. No help.
- FURRYe38Jan 25, 2020Guru - Experienced User
Is this the only device that seems to have problems? I would make contact with the devices mfr and ask for help and information regarding this.
