Gellie
Jan 25, 2020Aspirant
Logitech Squeezebox continues to lose connectivity
Just started. Not sure if there was some software update? It stays connected to the 2.4ghz satellite (25 feet away) for several hours, perhaps days. Then disconnects and I need to reboot the Touch. A...
Gellie
Running 2.5.1.8. Tried all channels you mentioned. I have unplugged Fios router, main Orbi and the 3 satellites. No help.
Jan 25, 2020Guru - Experienced User
Is this the only device that seems to have problems? I would make contact with the devices mfr and ask for help and information regarding this.
