mkbrand
May 24, 2019Aspirant
Logitech Squeezebox Won't stay connected to rbk50
I have 3 logitech squeeze box classics(running on 2.4 ghz) using the Logitech Media server to send music from my computer to my stereos It does not work with my RBK50 (I have one satelite). It con...
May 24, 2019Guru - Experienced User
Is the Orbi system operating in Router or AP mode?
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials when wirelessly connected.
Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
