mkbrand
May 24, 2019Aspirant
Logitech Squeezebox Won't stay connected to rbk50
I have 3 logitech squeeze box classics(running on 2.4 ghz) using the Logitech Media server to send music from my computer to my stereos It does not work with my RBK50 (I have one satelite). It con...
May 28, 2019Guru - Experienced User
Any progress on this?
mkbrand wrote:I have 3 logitech squeeze box classics(running on 2.4 ghz) using the Logitech Media server to send music from my computer to my stereos It does not work with my RBK50 (I have one satelite). It continually drops connection, stops music, reboots the squeezebox unit, and occasionally sends screeching sounds through the speakers. I don't have any other problems with the Orbie; it covers my house with stong consistent signal. But my music system is non-functional. has anyone out there had this problem? Or, more importantly, solved this problem?
Thanks for your help.
mkbrand
May 28, 2019Aspirant
Unfortunately, I have not made any progress on this issue. I have not had time try the suggestions that were given. I will keep you posted if any of the items suggested work. Thanks for your help.
- FURRYe38May 28, 2019Guru - Experienced User
Ok, please let us know. Also please give feedback to the questions presented when you get time.
