Conax
Sep 12, 2017Guide
Logs in Administration on displays one hours of log (ORBI RBR50)
I'm using Orbi RBR50, and would like to check what sites my children have been onto. But the logs in Administration only shows activities in the last hour. How do I get more than that?
DarrenM
Sep 14, 2017Sr. NETGEAR Moderator
Hello conax
Orbi does not have a in depth feature like that you may have to look for some other software.
DarrenM
Conax
Sep 15, 2017Guide
Thank you Darren for your reply. This is however quite disappointing, consider this is not a set of cheap devices, and that if it has the capability of writing logs why restricted it to just an hour?
