rstopcpa
Jul 06, 2020Follower
long range wifi solutions
I'm looking for a wifi solution that can cover an area of approximately 500 diameter from the unit, if it exists. I have an outbuilding on my property and would like to install wireless cameras. Our ...
CrimpOn
Jul 13, 2020Guru - Experienced User
rstopcpa wrote:I'm looking for a wifi solution that can cover an area of approximately 500 diameter from the unit, if it exists.
Regular WiFi systems coverage falls off dramatically after 50' or so. In "open air", they might cover 100' or more. 500' is TOO FAR. This is independent of brand.
And, 500' is farther than an ethernet cable run is designed to support.
There are "wireless bridge" producs designed specifically to create a link over distances up to several miles. They have focused antennas.
A lot of companies make them. Ubiquiti is one that gets good reviews from users on this forum. Netgear has one product of this type. To support IP cameras in a building 500' away, the typical solution would be to install a wireless bridge to connect that building with the main building and install a regular WiFi access point out there for the IP cameras to connect to. (Or, if the IP cameras are "wired" cameras, install a switch in the remote building.)
