richwoodUser
Jul 13, 2017Tutor
Long time for device to initially connect to internet when on Orbi wifi
I have the Orbi RBK40. Everything works except anytime i turn on a device it takes 30-60 seconds for the device to connect. Once connected, internet is fast. The device connects to the wifi immedi...
- Jul 14, 2017
Do you have the modem router in bridge mode so the 2 routers are not having conflicts? That could be why it takes to long to connect as both routers are trying to do the same job.
DarrenM
DarrenM
Jul 14, 2017Sr. NETGEAR Moderator
Hello RichwoodUser
Are you using orbi in router or AP mode? do you use some sort of modem router combo that is connected to orbi?
DarrenM
- richwoodUserJul 14, 2017Tutor
Hi Darren, Thanks for the reply.
No I am not using AP mode. I have a modem router that feeds into the Orbi. I have never had problems with any other router with this setup.
Thanks in advance,
Bo- DarrenMJul 14, 2017Sr. NETGEAR Moderator
DarrenM
- richwoodUserJul 15, 2017Tutor
Thanks Darren, It looks like that was the problem. When I removed the 2nd router, everything worked. Wierd that it worked with my other router the Orbi replaced. Thanks so much!
Bo
