ChristineT
Aug 14, 2018NETGEAR Employee Retired
Looking for a select group of Orbi Community members that are interested in beta testing firmware
Greetings Orbi Community,
We are looking for a select group of Orbi Community members that are interested in beta testing current and upcoming Orbi firmware to help broaden our scope of use cas...
RocketSquirrel
Aug 16, 2018Luminary
ChristineT, can you provide any details of "Significant bug fixes for stability & performance"? That would influence my decision to test. Thanks.
- ChristineTAug 20, 2018NETGEAR Employee Retired
Greetings RocketSquirrel,
Thank you for your interest in participating! Are there specific issues that you are experiencing that I can ask the engineering team to confirm has been fixed in this release?
Thank you kindly,
Christine
- standarduser73Aug 20, 2018Tutor
Are there "requirements" to get in to the beta program? I would like to try out the beta to see if it resolves my client stability issues, and my issues with a wired backhaul.
- RocketSquirrelAug 21, 2018Luminary
Thank you kindly,
Christine
Yes, ChristineT, a couple of issues. Thanks for asking.
1. Setting up wired backhaul is a long, frustrating process. Instructions imply it should "just work", but users (including me) have experienced network storms and long waits for stabilization before wired backhaul begins to work.
2. Wired Orbis tend not to recover after a power glitch, bringing down the entire LAN. They require tender loving care and quite a bit of time to get back up and running. A split-second power glitch has caused me to spend 30-60 minutes baby-sitting my network to get it up again. (I now have all 3 Orbis on UPSes.)
3. The QOS GUI page confuses users because there's nothing there but a speed test.
- toeAug 21, 2018Apprentice
Exactly. I will not be interested in testing the beta firmware unless it fixes all the convergence issues with wired backhaul
