wfmiller13
Jun 22, 2017Follower
Looking for advice on wireless bridge function help!!
Currently I have 4 devices in my family room plugged in via etherneet to a powerline bridge. They connect to another unit that is plugged into the powerline in my home office which then connects via ...
st_shaw
Jun 22, 2017Master
You can place an Orbi satellite in your family room and connect wired devices to it. It will serve as a wireless bridge to the Orbi router, using the Orbi backhaul. The caveat is the router and satellite must be close enough to get a good signal. I have my system setup this way.
- sunildaxJun 27, 2017Star
By when is the wired ethernet link between the router and satellite expected for the RBK50?
