wfmiller13
Jun 22, 2017Follower
Looking for advice on wireless bridge function help!!
Currently I have 4 devices in my family room plugged in via etherneet to a powerline bridge. They connect to another unit that is plugged into the powerline in my home office which then connects via ...
OrbiMan
Jun 28, 2017Luminary
I did this putting 2 Orbi near each other causing havoc with band steering and roaming between Orbi and ultimately cause problems. I use an old Netgear Nighthawk R7000 with DDWRT and use it as a bridge which works. Now if I could figure out the backhaul wifi password then it would be even better
