pbGuy
Feb 25, 2019Aspirant
Looking for Stable & Reliable WiFi with Increased Speed
I'm considering replacing my current router/switch with either the RBK50 bundle (1 RBR50 + 1 RBS40) or RBK40 bundle (1 RBR40 + 1 RBS40). As I've not yet purchased, here are details which should paint...
Feb 28, 2019Guru - Experienced User
It's preferred to have 1Gb minimum which is the max most ISP offer currently since the RJ45 ports on most modems and routers and LAN adapter cards and such only support up to 1Gb max. If some isps are pushing more than 1Gb then yes, the WAN aggregation can take advantage of this higher speeds. Mostly seen in business or enterprise environments. Most home envrionments probably would not have a need for Aggregation. The Aggregation also works on slower ISP speeds as well.
