SteveAtHomeCIO
Aug 04, 2021Tutor
Looking for the best / most stable firmware for my Orbi network (RBR50 + RBS50 + RBW30)
I saw that 2.7.3.22 is currently available for my RBR50 and although I NEVER upgrade to the most recent software version as soon as it is released, the update notification did make me think about whe...
Aug 04, 2021Guru - Experienced User
I enjoyed v104. If you update you may get v22 updated from NG automatically.
If your system is working you might want to just keep it running on whats loadded. Until such time as it real maybe needed.
SteveAtHomeCIO
Aug 04, 2021Tutor
Thank you!! I get periodic (once every few weeks) reboots but stable aside from that. I recently modified the WAN_LEASE setting to see if that would fix the reboots and will let that settle to see if that is the fix for that but if there are other reasons to upgrade (e.g. security fixes / features), I'd consider a move to another stable relaese.
- FURRYe38Aug 04, 2021Guru - Experienced User
You might try a factory reset and setup from scratch if that hasn't been done in a while and see if it clears the reboot item.
I ran v104 for a while. No issues seen for me.
- SteveAtHomeCIOAug 04, 2021Tutor
It's a FiOS ONT model ALCATEL-7342L
đ Ok, just checking for a router here. It's a ONT only.
