SteveAtHomeCIO
Aug 04, 2021Tutor
Looking for the best / most stable firmware for my Orbi network (RBR50 + RBS50 + RBW30)
I saw that 2.7.3.22 is currently available for my RBR50 and although I NEVER upgrade to the most recent software version as soon as it is released, the update notification did make me think about whe...
Aug 13, 2021Guru - Experienced User
Good to hear. đ
Be sure your laptops wifi and ethernet drivers are up to todate as well.
SteveAtHomeCIO
Aug 13, 2021Tutor
The drivers are company controlled (work laptop) and the IT dept keeps them fairly up to date. But, the image we run is sooo burdoned with other stuff that the issue is most likely with the laptop (and not the Orbi).
- FURRYe38Aug 13, 2021Guru - Experienced User
Ok then. Good ol IT. :smileyfrustrated:
Enjoy.
- SteveAtHomeCIOAug 20, 2021Tutor
UPDATE: Two nights ago, my Orbi rebooted in the middle of the night. How did I know? My daughter complained about a blue light in the hallway (RBW30) "fading in and out" at 2am. So I figured that the router just rebooted again and I resolved to upgrade to 2.7.2.104. However, things got interesting when my wife started complaining about slow speeds the next day and my laptop dropped internet again. Taking a look at the router I noticed that it had auto-updated to 2.7.3.22!!!
I'm sorry, but Netgear has not earned my trust enough to autoupdate so I dropped back to 2.7.2.104 on both my RBR50 and RBS50. Also factory reset both after the downgrade and neutered the routers ability to auto-update again by telnet-ing into the router and performing the following...
$ nvram set orbi_auto_upgrade=0
$ nvram set auto_check_for_upgrade=0
$ nvram set auto_update=0
$ nvram commitI'll keep you guys posted on the stability of the network now that I'm downgraded.
Another UPDATE: Woke up this morning to no internet. After catching an earful from the family, a simple restart of the FiOS ONT fixed it. So why did I lose connectivity in the middle of the night? You guessed it, the router re-booted after upgrading itself to 2.7.3.22.
I just consulted the network team at my company, and after discussing requirements, I bought an Eero Pro 6 - 3 pack from Amazon but the good news for you folks is that I have an RBK-50 (RBR50 & RBS50) and RBW30 available for sale with recently upgraded firmware!
