mikedesj's avatar
mikedesj
Follower
Jul 24, 2017
Looking for wireless card for desktop to work with Orbi
Purchased the RBK50 for my house.  Existing desktops have Wireless N adapters.  I am wanting to replace them with a wireless card that will take advantage of the Orbi WiFi.
I have an open PCI Express x1 slot for the card.
Understanding that a wired connection is or may be the best to use for speed I would still like to get a wireless adapter that would take advantage of the Orbi speeds in the event I need to swith to a wireless connection.
Any input would be appreciated.
Thanks,
Mike D.
  • Orbi is 802.11ac, dual band, with 2x2 radios. Max link speed of Orbi is 400 Mbps on 2.4GHz and 867 Mbps on 5 GHz. You should buy something with at least these specs.
    Mike D.
    to be honest you cant go past the asus pce-ac68 for its coverage and separate antenna array and throughput , its actually a bit faster than the orbi but better to have more capacity than less
    pete
  • I'm using the Asus PCE-AC88 PCI express card and it works fantastic for me. I have 500/50 service and get the same speeds on my desktop that I would get on a hardline throughout the house. It's newer than the PCE-AC68 and has an extra antenna (4 vs 3). At only $20 more than the AC68, it's definitely worth it for the increased range and possible future proofing.
