RAE1973
Jul 31, 2019Aspirant
Looking to buy The ORBI OUTDOOR Range Extender but will it work?
I currently use an AC900 Nighthawk R7000 router and it covers my entire home quite well except for one issue. Outside on the patio it works well when the sliding glass doors are open, but when they a...
Jul 31, 2019Guru - Experienced User
Orbi out door RBSY models only work with Orbi systems. They won't connet to other NG routers.
- RAE1973Jul 31, 2019Aspirant
interesting, the netgear website says it can connect to the Nighhawk R7000
- CrimpOnJul 31, 2019Guru - Experienced User
Maybe we are talking about different devices. The Orbi RB50Y is what we think of as the "outdoor" unit. I looked at the product web page, and did not see a reference to connecting it to the Nighthawk line. https://www.netgear.com/orbi/rbs50y.aspx
Is this the unit you are talking about?
Can you send a link to the reference?
Thanks
- RAE1973Aug 01, 2019Aspirant
The unit I am referring to is here: https://www.netgear.com/orbi/rbs50y.aspx
It claims that it can be connected to any router. My router is the Nighthawk AC1900 / R7000
