Saturn007
Nov 27, 2019Aspirant
Looking to purchase a RBK50-100AUS
Interested in purchasing a RBK50-100AUS (https://www.amazon.com.au/Tri-Band-High-Performance-Satellite-Extender-RBK50-100AUS/dp/B077CRK886/ref=cm_cr_arp_d_product_top?ie=UTF8&th=1) & still undecided....
Saturn007
Dec 01, 2019Aspirant
Thanks for the replies & much appreciated.
I've changed my plans now where having fast roaming or mesh or similar isn't really an issue for me. I need strong wifi signals along with split 2.4/5 & have now purchase a 'Ubiquiti UniFi UAP-AC-LITE Dual-band AC1200' which I will install in an appropiate location.
This will have splt 2.4/5 & if the signal is better than my existing wifi (which I think it will be - NG WNDR3700v2) then I'll turn off the old wifi & leaving routing on, rename the Ubiquiti split wifi's & give them the same passwords. Then further down the line purchase a few more & place them around the house where I have CAT cabling.
Installed a VM & the software for the Ubiquiti & now just wait for the device.
Cheers
Dec 02, 2019Guru - Experienced User
Enjoy. :smileywink:
