sandman512
Jan 12, 2022Apprentice
Looking to temporarily disable the the 5GHZ network as to allow my device to connect to the 2.4 GHZ
So, I have an Orbi mesh system , a RBR50 with 3 satellites. I have a device that can only connect to the 2.4 GHZ band. Is there a way to either temp. turn off the 5ghz until the device connects or fo...
- Jan 12, 2022
UPDATE: So,I turned on location services for the WYZE app and everyting worked. Thanks!
sandman512
So, it's a WYZE cam V3. I was able to connect on camera to the router in question(its further from the router) and I was able to confirm that it is on the 2.4 GHZ network. When attempting to connect another WYZE CAM, the error messages happens after I enter the Network name and password; it says cannot locate network. FWIW, this has appended on TWO brand new Wyze CAMS.
CrimpOn
Jan 12, 2022Guru - Experienced User
I have three Wyze cams connected to my Orbi. V2, Pan Cam, and V3. All connected with no problem. As I recall, Wyze cams work the same way as most security cameras. The Wyze 'app' creates a QR code and the camera is pointed at the QR code. That is what the Wyze Cam V3 says to do:
https://support.wyze.com/hc/en-us/articles/360050638272-Wyze-Cam-v3-Setup-Guide
I always do the initial setup of Internet of Things (IoT) devices in the same room as the Orbi router. I like to be able to open the Orbi web interface and see that the device appears in the Attached Devices table before deploying it somewhere else.
My first thought is a typo in the WiFi SSID/password entry. Second thought is the location does not have enough WiFi signal. (unlikely)
- sandman512Jan 12, 2022Apprentice
Appreciate the help. So, I have had two new cameras and BOTH wont connect after I enter the WiFi SSID/password entry. I called WYZE and they indicated that is was because the device was ONLY recognzing the 5GHZ channel and not the 2.4. I tripled checked my wifi SSID/password.
- CrimpOnJan 12, 2022Guru - Experienced User
This is SO disappointing. The Wyze Cam V3 has only a 2.4G radio:
https://support.wyze.com/hc/en-us/articles/360051119371-Wyze-Cam-v3-Tech-Specs
Read it in black and white.
Connectivity
2.4GHz WiFi
It is (literally) impossible for the Wyze Cam V3 to detect a 5G WiFi signal. Just as it cannot detect AM/FM radio or detect cordless phone signals. Just not possible. That tech is either incompetent or misinformed.
I have had mixed results when contacting tech support (not Wyze, but many other companies). Sometimes I call back and get a rep who is better prepared. (Digression: I once had a problem with my cable TV 'tuning adapter'. Spectrum rolled a technicial who replaced the tuning adapter with both of the units on his truck. Neither worked. He then met another tech and got the two adapters on that truck. After eight hours, he said, "I dunno. My shift is over" and left. He had called into Spectrum at least 12 times (gone through the whole phone tree mess and everything). Before driving to the Spectrum store to swap for a 5th tuning adapter, I called Spectrum customer service. Got a nice woman who said, "Hold on. Your account is coded incorrectly. Can you try it again?" Sure enough, worked fine.
Can you make one more call?
And, can you try to configure it in the same room as the Orbi router?
I believed you before you posted that, but thank you! So, I noticed something of interest. In my IPHONE, under the WYZE app, the location was turned off. So, I am going to allow it to use my location when using the APP. I have a funny feeling that this is going to be in the issue. Unfortunately I am at work and cannot test my theory. Your thoughts?
