sandman512
Jan 12, 2022Apprentice
Looking to temporarily disable the the 5GHZ network as to allow my device to connect to the 2.4 GHZ
So, I have an Orbi mesh system , a RBR50 with 3 satellites. I have a device that can only connect to the 2.4 GHZ band. Is there a way to either temp. turn off the 5ghz until the device connects or fo...
- Jan 13, 2022
UPDATE: So,I turned on location services for the WYZE app and everyting worked. Thanks!
sandman512
Appreciate the help. So, I have had two new cameras and BOTH wont connect after I enter the WiFi SSID/password entry. I called WYZE and they indicated that is was because the device was ONLY recognzing the 5GHZ channel and not the 2.4. I tripled checked my wifi SSID/password.
CrimpOn
Jan 12, 2022Guru - Experienced User
This is SO disappointing. The Wyze Cam V3 has only a 2.4G radio:
https://support.wyze.com/hc/en-us/articles/360051119371-Wyze-Cam-v3-Tech-Specs
Read it in black and white.
Connectivity
2.4GHz WiFi
It is (literally) impossible for the Wyze Cam V3 to detect a 5G WiFi signal. Just as it cannot detect AM/FM radio or detect cordless phone signals. Just not possible. That tech is either incompetent or misinformed.
I have had mixed results when contacting tech support (not Wyze, but many other companies). Sometimes I call back and get a rep who is better prepared. (Digression: I once had a problem with my cable TV 'tuning adapter'. Spectrum rolled a technicial who replaced the tuning adapter with both of the units on his truck. Neither worked. He then met another tech and got the two adapters on that truck. After eight hours, he said, "I dunno. My shift is over" and left. He had called into Spectrum at least 12 times (gone through the whole phone tree mess and everything). Before driving to the Spectrum store to swap for a 5th tuning adapter, I called Spectrum customer service. Got a nice woman who said, "Hold on. Your account is coded incorrectly. Can you try it again?" Sure enough, worked fine.
Can you make one more call?
And, can you try to configure it in the same room as the Orbi router?
- sandman512Jan 12, 2022Apprentice
I believed you before you posted that, but thank you! So, I noticed something of interest. In my IPHONE, under the WYZE app, the location was turned off. So, I am going to allow it to use my location when using the APP. I have a funny feeling that this is going to be in the issue. Unfortunately I am at work and cannot test my theory. Your thoughts?
- CrimpOnJan 13, 2022Guru - Experienced UserMight. Certainly worth a dshot.
- sandman512Jan 13, 2022Apprentice
Thanks, I will update this thread! Funny thing is that I am typing the exact SSID in. Now that I enabled the locations services, it will recognize the nearby NETWORK. Hopefully just enter the password and BINGO!
- N3tworkDud3Jan 23, 2022Apprentice
CrimpOn wrote:This is SO disappointing. The Wyze Cam V3 has only a 2.4G radio:
Connectivity
2.4GHz WiFi
So a little FYI - the WYZE Cams don't need the speed 5 GHz networks provide. They need distance. The 2.4 GHz network provides the greatest disatnce so that's the radio they included.
Not including a 5 GHz radio helps keep costs down too.
I've got a few Wyze Cams myself and only have isseus with them dropping of fthe network at times. The issue isn't them, but the Firmware Netgear threw out there on the routers and satellites. I know this to be true as they are not the only devices with thiis issue among other things.
