sandman512
Jan 12, 2022Apprentice
Looking to temporarily disable the the 5GHZ network as to allow my device to connect to the 2.4 GHZ
So, I have an Orbi mesh system , a RBR50 with 3 satellites. I have a device that can only connect to the 2.4 GHZ band. Is there a way to either temp. turn off the 5ghz until the device connects or fo...
- Jan 12, 2022
UPDATE: So,I turned on location services for the WYZE app and everyting worked. Thanks!
sandman512
Thanks, I will update this thread! Funny thing is that I am typing the exact SSID in. Now that I enabled the locations services, it will recognize the nearby NETWORK. Hopefully just enter the password and BINGO!
sandman512
