Doverman
Sep 05, 2019Follower
Looking to use Orbi to replace Verizon Fios modem with no STBs but with 1gb internet and telephone
New to the forum. Looking to dump Verizon FIOS modem that caps out at 300mbs speeds. Paying for 1gb and can't access it with FIOS gear. Also have 4,000 sqft to support with coverage and barely get...
Sep 05, 2019Guru - Experienced User
You need to contact your ISP first and see what non ISP provided modems are supported on there system.
The CBK40 doesn't support phone connections. The NG CM1150v does. If they support this modem, you could get into this modem and then attach a RBK50 series Orbi system to this modem.
